Need chip/tuner help
TS 6 position chip. You can buy it from many different vendors. I recommend getting one that has lifetime free reburns. Be ready to spend 400 to 500 on the chip and custom tuning. I bought one with generic tunes and it helped the truck significantly! I have an auto and it helped shifting etc. WHEN you start adding injectors.. turbo.. hpop and any other goodies you'll want to get it re-burnt to make it run the best.
I see you're fairly new here with a newfound truck..
Be warned the power will get addictive and you'll want more. That few hundo you'll spend on a chip will be cute once you start moving into the big stuff. I started the same way. Intake. Exhaust. chip. Then you throw in $1400 in injectors. Then $3500 for trans (at a minimum, more like $5k). It doesn't end.
I think buying one of these trucks quickly turns into a disorder known as Powerstroke Modification Syndrome...its highly addictive i hear...
Personally I don't mind spending money on the truck..just wish I had more to spend lol..
1L243
30
11-02-2011 10:21 PM
nick7.3
08-26-2010 07:27 AM
