Ordering a BPD oil cooler tomorrow!
#31
Well guys, I finished up the BPD oil cooler install Saturday and my truck is at a local shop getting the AC system recharged right now. The install was actually not bad at all. The hardest part was getting the transmission cooler out so I could put the lowering brackets on. Everything else was a breeze! Now my oil temps are staying lower than my coolant temps by an average of about 7-10 degrees. Well worth the money IMO!
E series are a fair bit different than F series
in configuration.
i've only gotten it hot once since then, pulling up an elevator shaft
with 15,000# of weight. floored in first, going 11 mph. (nine mile
canyon to kern plateau.)
otherwise, i've not seen oil, coolant, or trans temps top 200.
yeah, it's expensive. zero complaints. it solves a lot of problems.
#32
#33
I can tell you my sons trans never gets hot or coolant but the oil temp pulling 16K threw the desert in the summer going up hwy40 or 5 here the oil temp can get to 250 degrees. So get the biggest oil cooler that comes with it. I talked to them and they told me they new of the problem and wanted another $600.oo for the new cooler. Not very good business if you ask me. There in Arizona they should of had it worked out. And he dose have the remote filter.
65F100project
10-03-2006 05:33 PM
Dustin_86
09-02-2006 12:32 AM
