Ordering a BPD oil cooler tomorrow!
  #31
Old 05-04-2015, 01:40 PM
Fulthrotl's Avatar
Fulthrotl
Fulthrotl is offline
Originally Posted by LSO1123
Well guys, I finished up the BPD oil cooler install Saturday and my truck is at a local shop getting the AC system recharged right now. The install was actually not bad at all. The hardest part was getting the transmission cooler out so I could put the lowering brackets on. Everything else was a breeze! Now my oil temps are staying lower than my coolant temps by an average of about 7-10 degrees. Well worth the money IMO!
i put the full BPD on my van 55k miles ago.
E series are a fair bit different than F series
in configuration.
i've only gotten it hot once since then, pulling up an elevator shaft
with 15,000# of weight. floored in first, going 11 mph. (nine mile
canyon to kern plateau.)
otherwise, i've not seen oil, coolant, or trans temps top 200.
yeah, it's expensive. zero complaints. it solves a lot of problems.
  #32
Old 05-04-2015, 01:58 PM
HT32BSX115's Avatar
HT32BSX115
HT32BSX115 is offline
HOW HOT? And, did you have the HD cooler, filter and T-stat? (Inyokern to Lake Isabella?)
  #33
Old 05-04-2015, 07:24 PM
Bonanza35's Avatar
Bonanza35
Bonanza35 is offline
I can tell you my sons trans never gets hot or coolant but the oil temp pulling 16K threw the desert in the summer going up hwy40 or 5 here the oil temp can get to 250 degrees. So get the biggest oil cooler that comes with it. I talked to them and they told me they new of the problem and wanted another $600.oo for the new cooler. Not very good business if you ask me. There in Arizona they should of had it worked out. And he dose have the remote filter.
craziejoker
06-05-2015 07:47 PM
KJNDIVER
10-17-2011 07:26 PM
teppler
05-04-2010 09:31 AM
65F100project
10-03-2006 05:33 PM
Dustin_86
09-02-2006 12:32 AM
Quick Reply: Ordering a BPD oil cooler tomorrow!
