Early 2004 HPOP problem
Old May 1, 2015 | 03:39 PM
Auburn-F250's Avatar
Auburn-F250
Hi all. Brand new to the forum. I have an early 2004 F250 6.0 and recently began having issues where the oil pressure indicator would drop to nothing at idle. It was fine when I rev'd it to about 1000 RPM but as soon as it dropped below that the needle would zero out. Likewise, the next morning the truck took a really long time to crank.
With those symptoms, I figured it was a problem with the HPOP based on threads I had read. I decided to go after the HPOP hoping to find a clear problem. I was able to get to the pump today and when I pulled it, I immediately noticed that the little metal ball was gone on the driver's side of the pump. I had read that this was a very common issue on these pumps. So I'm assuming this is the culprit to my problem.
I have 2 questions for the forum:
1. Do I have to replace the entire HPOP? I read a thread that said I could simply tap the hole and plug it (no need to replace the entire pump). Thoughts on this? It sure would be nice to fix this without dropping $600-700 for a new pump...
2. Now I guess I have to find the missing ball. Of course no luck finding it where the pump was located. I'm guessing it made its way down to the oil pan. Do I just need to drain the oil and pull the pan? Any other suggestions?
Thanks!
Old May 1, 2015 | 05:44 PM
dannyboy950's Avatar
dannyboy950
If it is in the pan sometimes dragging a magnet across the bottom of the pan you can work the ball out the drain hole.
I have tapped a number of pumps and heard of many others doing it also.
Old May 1, 2015 | 07:20 PM
Auburn-F250
Thanks dannyboy950. I'll try that route. So based on your reply, a question I was going to ask, the ball is small enough to fit thru the drain hole?
Old May 1, 2015 | 07:38 PM
cheezit's Avatar
cheezit
Tap the hole.
The ball should be just fine sitting in the pan. Its heavy and wont float in the oil. Its also to big to get sucked into the screen.
The hole where the drain plug is has a raised bung on the inside.
If it bothers you stick a rare earth magnet to your oil pan
Old May 2, 2015 | 12:33 PM
05F250DSL's Avatar
05F250DSL
If you are referring to the oil Guage on the dash if does not read hpop. It reads low pressure oil system. behind the harmonic balancer is the oil psi regulator. It has a allen head on it. Remove that and make sure it is free moving and clean. There is a spring in there so be careful when you remove the end. If you are referring to an a/m Guage you have nevermind what i said. But the missing ball is an problem.
Old May 3, 2015 | 10:49 AM
Tampa250's Avatar
Tampa250
Guys, just for my own general knowledge here- if that check ball is missing on a HPOP that isn't doing its job, tapping and plugging that hole is all that needs to be done to fix it? Is this the sole cause of failure on the pump? I ask because the HPOP on my early '04 started getting very weak recently and I had the pump replaced. Too late now, but I'm curious if the pump completely failed or if this was my issue. My truck has about 150k on it.
Old May 3, 2015 | 10:54 AM
BLADE35's Avatar
BLADE35
It will work to tap the pump if only the ball blew out follow cheezit advice
If there weak then internals is jacked up or case spins
There's some info on it in my thread
Old May 3, 2015 | 11:04 AM
BLADE35's Avatar
BLADE35
https://www.ford-trucks.com/forums/1...op-storey.html
A HPO Problem can cause LPO problems all his oil was dumping threw his HPOP causing that LPO to show Low pressure on low press side
Old May 3, 2015 | 11:12 AM
BLADE35's Avatar
BLADE35
Anyone think that ball is a saftey
Old May 4, 2015 | 09:09 AM
Super Duty Service's Avatar
Super Duty Service
Former Vendor
Here's a vid I shot last week.
Old May 4, 2015 | 10:09 AM
dannyboy950
I have been trying to find out what that actually does if anything for awhile.
Hope you find out.
Old May 4, 2015 | 02:47 PM
cheezit's Avatar
cheezit
Imo its a casting plug.
Old May 4, 2015 | 08:54 PM
dannyboy950
Casting plug has been the general consensus that I have seen. At one time I thought it might be a check valve but then it doesn't useually move any.
Glenn54
Oct 18, 2016 11:48 AM
ZebraStripe
Aug 12, 2010 12:00 AM
shorod
Dec 6, 2009 11:06 PM
Stroker09
26
May 20, 2008 07:07 AM
bill farrell
Mar 13, 2005 11:34 AM
