2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Light Tick/Knock/Click Engine Sound
Old 04-14-2015, 01:59 PM
afr's Avatar
afr
afr is offline
Good day everyone!
I recently purchased a 2009 Expedition Eddie B with 40k miles. 5.4L V8.
I'm noticing a light clicking/knocking sound that matches the rpm and disappears around ~2000 rpm. The noise is present when the motor is cold or warm, in any gear.
I can only hear the sound from the inside of the car with the doors shut, but It's definitely coming from the other side of the firewall.
I hope I didn't make a mistake with this beautiful automobile.
Thanks for your help!
Old 04-16-2015, 09:32 AM
slenser's Avatar
slenser
slenser is offline
It wouldn't be the injectors, would it? They're pretty noisy.
Old 04-16-2015, 09:39 AM
afr's Avatar
afr
afr is offline
Thanks for the Reply - slenser.
I shouldn't have included the word "knock". It's a very light tick that I only notice when the engine is idle, or moving slowly. Maybe it's just something I'm not used to...
I hasn't seemed to get any louder.
Thanks again.
Old 04-20-2015, 12:56 PM
79F150400M's Avatar
79F150400M
79F150400M is offline
Mine does it too but Ive narrowed it down to the transmission since it doesn't do it in Park. Id say its more of a clicking sound and not a knock. My Navi is a 2010 with 49,000mi
Old 04-21-2015, 10:07 AM
slenser's Avatar
slenser
slenser is offline
79F150400M,
Does it do it when it's moving only or when it's stopped as well?
Old 04-21-2015, 01:22 PM
79F150400M's Avatar
79F150400M
Originally Posted by slenser
79F150400M,
Only when it's moving between 20 and 40mph and in Drive. Seems to be quieter if I put it in 3rd or 2nd gear.
Old 04-21-2015, 11:01 PM
slenser's Avatar
slenser
slenser is offline
Makes me wonder if there's something in your drive train. Maybe check the driveshaft for something wrapped around it or even something with the tires. Start with the simple possibilities before moving onward.
Old 04-25-2015, 03:24 PM
gaffer222's Avatar
gaffer222
gaffer222 is offline
Maybe a cracked exhaust manifold or manifold gasket. Had the issue on both sides 2 years apart. Both covered under ext warrantee
SirArgus
1983 - 2012 Ranger & B-Series
06-15-2012 08:58 AM
sourmashpdx
06-12-2012 04:44 PM
Phantez
01-29-2012 06:17 PM
JerrySC
3.8 & 4.2L V6
01-27-2008 11:19 AM
rudace
11-27-2006 10:10 AM
Quick Reply: Light Tick/Knock/Click Engine Sound
