1997 f250 upshifting very quickly all the sudden and will not downshift when given throttle???
So all the sudden my truck upshifts through the gears very quickly. Even just driving 20-30mph it goes up all they way to 4th gear. If I mash on the gas it will not down shift. It only goes back to first gear if I damn near stop. This just started happening instantly; it was not gradual. everything was fine one minuit then it started doing this. What should I look for? Is it just trash in the fluid? A solonoid? Sensor?
You have a fault in the trans circuits. The od cancel light should be flashing.you will have to get a good shop or dealer to pull the code and see what the issue is.
It is shifting that was as it is in "limp home" mode.
Does the od cancel light work if you disable od? I am willing to bet it does not if when it is in limp it does not flash.either way you have codes. What tuning device do you have?
Super chips micro tuner. I just drove the truck around the parking lot here at work and couldn't get it to do it. Hit the OD button on and off a few times with no lights. I'll have to see what it does after work?
Well, oddly enough; the truck fixed itself. Drives and shifts as normal. My guess is that trash got in a line and caused it to go into limp mode? When I turned the truck off and let it sit the debris fell back in the the pan??? Thats my uneducated transmission guess anyway.
If your od light does not work then you should have it checked for codes. The trans could be warning you of something wrong, it could be a cheap repair now or a pricey one later. I don't really believe that crud worked its way out.
You HAVE a problem. Yes the shifter when you cancel od the "off" lights up.
That will flash when there is an issue. when you key off and back on it can restart but once its up to temp my bet is it messes up again.
