balancing weights on mag wheels
If you can't see me, I'm just shaking my head......having worked in a good ol fashion gas station through school, I installed tires on custom rims without the touchless tire machines or coated arms (yes, use to use a lot of lube & rags to prevent scratching) and balanced wheels/tires with a static balancer and centrifical (on car) balancer....
Some people (IMHO) are just not able to use common sense......and yes, I have had (a couple of times) installers do that even on my chrome oem wheels......in theory they are right as this in theory is the best/accurate way to balance a wheel/tire assembly but, I don't plan on driving 140+ mph......and with mags, they have to wire brush the inside center portion (middle of the width section) to ensure the stick on weights will adhere properly...and yes, sometimes they do come off but 1) its very rare & 2) even if they do, just get the assembly re-balanced.....and lastly, they will balance just fine up to about 100+ mph.
and yes, I make them take them off and re-balance them!
I have also had my share of discussions regarding lug nut torque....as they tend to use an online generic listing where I bring my OEM service manual and show them....this is what to torque em too.....and typically it's less than what they were about to do..........
I took it back to the dealer and made them re-balance the wheels and put the stick on weights inside the wheel, it looks much better and is smoother. Those mf's just rushed through it the first time. I think it reflects badly on the dealer since the reason I replace the tires that were not worn out yet was the shaking, I could not get the old tires balanced. I made it clear I wanted the tires balanced properly and they just ignored me, Next time I will bring it to a high end wheel and tire dealer.
So much for saving 5 minutes of time...it now cost them 15 minutes to do what they needed to...
I was nice and just said to the manager, you might want to slow it down just a tad.........with a smile of course...
