exhaust smoke in engine bay
Old 04-08-2015, 06:58 PM
kupiec20's Avatar
kupiec20
kupiec20 is offline
in the past few months ive noticed excess ehaust smoke under the hood mostly during start up.
my truck exhaust is as tight as it can be
3in DP to a 4in strait pipe.
any thoughts?
278K on her.
Old 04-08-2015, 07:38 PM
stainlessstroker95's Avatar
stainlessstroker95
stainlessstroker95 is offline
Have you checked your exhaust manifolds? One of your bolts could have broke and now exhaust is leaking through.
Old 04-08-2015, 08:00 PM
cschulz135's Avatar
cschulz135
cschulz135 is offline
Sounds like the classic up pipe leaks. Spring for the bellowed ones. I just put a set on my F350 I picked up at O'Reilly's, they are made by Dorman. The quality was very good, much improved over the older iterations and possibly better castings than stock.
Old 04-09-2015, 11:09 AM
kupiec20's Avatar
kupiec20
kupiec20 is offline
ok
ill check both later
so whats an uppipe and how much and is it something i can do ?
Old 04-09-2015, 01:31 PM
fordman67's Avatar
fordman67
fordman67 is offline
Um..to my knowledge doorman does not do a kit for obs trucks...and their quality I have read is suspect anyway
Old 04-09-2015, 06:14 PM
cschulz135's Avatar
cschulz135
Yea, what do I know, I just put a set on. What you THINK is probably more accurate. To the OP, I'm not gonna lie, it's a pain in the neck to change out the pipes, but there are plenty of tutorials on here to show you how.
Old 04-09-2015, 08:38 PM
stainlessstroker95
Wow no need to by defensive. Maybe you could provide a link. I found super duty pipes on there site but non for obs. Nobody called you a lier either.
Old 04-09-2015, 08:48 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Did you put them on the truck that is in the picture beside your user name? If so, then that is a SD (Super Duty) '99-'03, not an OBS (Old Body Style) like the OP has and what Aaron was talking about. This is the '94.5 -'97 section of the forum.
Old 04-09-2015, 10:31 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
I think doorman calls them crossover pipes or something
Old 04-10-2015, 11:29 AM
fordman67's Avatar
fordman67
Wow...well then..
Old 04-10-2015, 03:52 PM
madpogue's Avatar
madpogue
madpogue is offline
Wow...well then..
+1; SD folks stinkin' up our section...
Back to the OP's question, the up-pipes carry the exhaust from the exhaust manifolds to the turbocharger. They go _up_ either side of the engine, on either side of the back end by the tranny. As said, PITA to reach. Look for soot on the insulation stuff on the firewall on either side; that's usually a tell-talle of an up-pipe leak.
Old 04-10-2015, 04:29 PM
fordpride's Avatar
fordpride
fordpride is offline
Dorman does make them for a SD but not for a obs to my knowledge. If you found some for a obs post a link
Old 04-10-2015, 06:51 PM
kupiec20's Avatar
kupiec20
kupiec20 is offline
me having a ZF-5 and efuel.
do that make my job less difficult?
Old 04-10-2015, 07:45 PM
madMatador78's Avatar
madMatador78
madMatador78 is offline
I can't say from experience that it's any easier, but the best thing I can tell you is take your time and go by yourself a 6 point box end wrench. It's slow and tedious work to do the job, but it can be done. Just did them on my truck. Not fun but the payoff Was well worth it.
Old 04-10-2015, 08:33 PM
fordman67's Avatar
fordman67
Its so much fun I'm on my second go around
Quick Reply: exhaust smoke in engine bay
