2012 ecoboost engine change
Old 04-08-2015, 05:50 PM
simenad's Avatar
simenad
simenad is offline
has anyone had experience changing engines on the 2012 f150? done plenty of older swaps but want to know what to expect with this one. Ecoboost blew because of an MSD plug so warrantee is not covering.
Old 04-08-2015, 07:12 PM
tvsjr's Avatar
tvsjr
tvsjr is offline
You blew a motor because of a spark plug? There's waaaaay more to this story. Warranty should cover it, assuming the spark plugs are materially equivalent to factory (Magnuson Moss).
Old 04-08-2015, 07:45 PM
simenad's Avatar
simenad
simenad is offline
MSD Spark plug porcelain detached and fell down over electrode so cylinder filled with gas and hydrolocked
Old 04-10-2015, 07:40 AM
tvsjr's Avatar
tvsjr
tvsjr is offline
I think I'd be getting a lawyer and going after MSD. Unfortunately, I don't think you're going to find many people who have done an engine swap on a truck that new.
Old 04-10-2015, 08:47 AM
MikeJ65's Avatar
MikeJ65
MikeJ65 is offline
I'm calling BS on this diagnosis.
Old 04-10-2015, 09:02 AM
Chad149's Avatar
Chad149
Chad149 is offline
Direct injection engines are much more sensitive to spark plug heat range and design. Op's description of the failure, while brief, is very plausible.
Op, have you done any other mods, tuner etc?
Old 04-10-2015, 09:09 AM
MikeJ65's Avatar
MikeJ65
MikeJ65 is offline
If loss of spark is going to hydrolock my 3.5L, I have one for sale.
Old 04-10-2015, 09:17 AM
Izzy351's Avatar
Izzy351
Izzy351 is offline
At least it would cause a mis-fire condition setting a code. I can't see the cylinder filling with gas because of lack of spark. I would expect the PCM to detect that and shut off that injector.
Unless a piece of the plug was knocking around in the cylinder and broke the injector. THEN I could see that possibly happening.
Old 04-10-2015, 10:13 AM
taxgod4u's Avatar
taxgod4u
taxgod4u is offline
You would have to have an exhaust valve failure at the same time to hydrolock
Old 04-10-2015, 10:14 AM
bmuhlbach's Avatar
bmuhlbach
bmuhlbach is offline
Wouldn't the exhaust valve still open to relieve the raw gas? I could see plugged cat.
Old 04-10-2015, 11:14 AM
Izzy351's Avatar
Izzy351
Izzy351 is offline
If the injector was broken and filled the cylinder, the compression stroke could cause a hydrolock condition, but I'm not sure it would happen without the broken injector. Why would the PCM continue fueling a cylinder it knows isn't firing??
Old 04-10-2015, 04:39 PM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,222 Likes on 804 Posts
Hoping to hear the whole story.
Old 04-10-2015, 05:42 PM
QwkTrip's Avatar
QwkTrip
QwkTrip is offline
Far fetched story. Either way, if engine is broke then it's broke.
Old 04-10-2015, 09:37 PM
RRRSkinner's Avatar
RRRSkinner
RRRSkinner is offline
The people here are primarily interested in protecting the reputation of Ford and ecoboost. They don't seem to know a whole lot either. Take off your shoe and ask it...I'm kind of kidding, but I would hope you could be assumed to be honest and get some help.
Old 04-10-2015, 10:14 PM
bdlesch's Avatar
bdlesch
bdlesch is offline
I have read that the MSD plug are known for this happening. Motorcraft SP534 are what everyone is saying to run. Also having weak spark from bad coils doesn't help. I don't see how a cracked plug porcelain can cause this damage....but I guess it did. Hope this doesn't happen to anyone else!
Quick Reply: 2012 ecoboost engine change
