#3 coil explodes
Old 04-03-2015, 11:37 PM
Bigbird0001's Avatar
Bigbird0001
Bigbird0001 is offline
#3 coil explodes
We have a 2002 Explorer 4.6 and the fuse for the coils keeps popping. We also have gone through 3 coils on the #3 cylinder that have blew up. the coil is all cracked and split at the base. If I disconnect the #3 coil and the fuse don't blow Please help. Brian
Old 04-04-2015, 08:58 AM
shorod's Avatar
shorod
shorod is offline
Have you measured the voltage to the coil and tried replacing the spark plug on that cylinder?
Next time you replace the coil you might try putting the new coil on a different cylinder and putting one of the existing coils on cylinder #3 to see if the new coil blows or if the used coil on #3 still blows. Maybe the coils you are getting have defects. Are they Motorcraft or aftermarket?
-Rod
Old 04-04-2015, 05:05 PM
Bigbird0001
Changed the plugs swaped the coils from other side still blows #3. Getting same voltage on #3 and #5 5 works fine.
Old 04-04-2015, 09:54 PM
shorod's Avatar
shorod
shorod is offline
You might want to check compression on cylinder #3 and make sure that it's getting fuel. Maybe it has low compression or poor fueling and that's straining the coil to attempt to fire a spark plug that doesn't have a decent compressed air/fuel mixture.
-Rod
Old 04-04-2015, 09:55 PM
Bigbird0001
Well looks like a melted wire harness was laying against the egr pipe thanks
okhunt
03-12-2008 11:26 AM
msm7c
1997 - 2003 F150
02-01-2005 11:51 AM
speedovr55
Modular V8 (4.6L, 5.4L)
12-11-2004 02:28 PM
pilot10
12-10-2003 04:25 PM
Quick Reply: #3 coil explodes
