Exhaust manifold removal-any secret to not breaking off the studs? they seem very tight! 460 gas
Is there any secret to removing the exhaust manifolds without breaking the studs off in the head...these studs and nuts seem really tight...do they always break?...whats your experience?...do you usually get the exhaust manifolds off without breaking a stud??...any help would be great..
Soak them for a week and when the time comes to finally remove them, get the engine warm for removal. I soaked mine for 3 weeks with PB blaster then when the day came to change them I took a quick loop of the neighborhood, pulled into the driveway where I had tools ready, threw on some leather gloves and went for it. Yes the manifolds were hot, but I got all of them cracked loose and backed out several turns without breaking a single one. Then I waited a little bit for things to cool down and went out to finish the job. Didn't break a single bolt.
Soak the hell outta them.
When you put a wrench on the bolt just turn it a tad then go back… then turn it a little then go back. Do that while soaking them AGAIN with your favorite rust penetrant. Be very patient and you will minimize breakage. Just a little wiggle… don't go all Chuck Norris on 'em and you'll be OK.
Corpsman24
26
05-30-2023 03:06 PM
drumfield
01-17-2010 03:50 AM
