C6 Transmission Help
You need to change the output shaft and the extension housing. Changing the housing is easy, just remove the 4x2 one and bolt the 4x4 one on. The output shaft is a little harder. The transmission needs to be totally torn down. The last piece out of the case is the output shaft. Then install the 4x4 shaft and rebuild the transmission.
Martin666
1983 - 2012 Ranger & B-Series
08-12-2015 08:03 AM
dorymate
10-04-2004 03:30 PM
