need help to disassemble bed
Old 03-27-2015, 12:36 AM
kg6tai's Avatar
kg6tai
kg6tai is offline
Does anyone have a diagram or pics on how to take the taillight panel and the bed sides off my 1959 styleside? I see all the spot welds and know I need to cut them I just want to know where to start.
Old 03-27-2015, 10:35 AM
Buzz44's Avatar
Buzz44
Buzz44 is offline
Im tempted to say at the begining so I will...... LOL........ I have those to do on both of my 4x4s with stylesides. I suppose I will start by grinding or wire brushing away every place that it looks like there will be a spot weld holding things together and start cutting them out and see how it goes. I do think that when the time comes to put that rear panel back on I would investigate some of the new adhesives I have been seeing that just glue the panel back on. They are said to be very strong and hold as good as welding..... hummmmm we will see. Good luck post up pics of how that goes for you. I will be watching and just thought I forgot I know have a 57 with a styleside bed too. That makes 3 I will have to do.....
Old 03-27-2015, 11:31 AM
kg6tai's Avatar
kg6tai
kg6tai is offline
I have three sitting here and need to two of them
Old 03-28-2015, 02:58 AM
kg6tai's Avatar
kg6tai
kg6tai is offline
I think I will hit harbor freight for a couple of spot weld cutters and see what I can do
Old 03-29-2015, 01:17 PM
Buzz44's Avatar
Buzz44
Buzz44 is offline
Please post pics if you can so we can see what you get up to with this one.
Old 04-03-2015, 12:21 AM
kg6tai's Avatar
kg6tai
kg6tai is offline
Here it is mocked up with bigger rubber
Had to trim the inside of the fenders for the bigger treads
Old 04-03-2015, 12:37 AM
kg6tai's Avatar
kg6tai
kg6tai is offline
I have a few parts trucks so I will pick the worse bed to start on that way I can use the sheet metal as filler panels
Canus
01-28-2017 04:50 PM
dgassett
Paint & Bodywork
10-02-2008 04:47 PM
Rosati
05-28-2003 04:07 PM
Quick Reply: need help to disassemble bed
