Suggestions needed for door handle shaft repair
Old 03-26-2015, 09:56 PM
tractormanbill's Avatar
tractormanbill
tractormanbill is offline
tractorman
I have seen window crank repair kits but I don't think I have seen any door handle shaft repair kits.
I don't think I have seen any new units available.
Anyone tore one down and took the wobble out of it?
TractormanBill
Old 03-26-2015, 10:21 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
Is this what you're looking for?
DOOR HANDLE REPAIR OUTSIDE 1948-1952
Old 03-26-2015, 10:29 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Those are to cure sagging handles, but won't do a lot of good if the door handle shaft isn't square any more.
Bill, I have never seen any repair kits. Weld'n'grind should be easy.
Old 03-27-2015, 04:26 PM
bobbytnm's Avatar
bobbytnm
bobbytnm is online now
Roast em' if you got 'em
Received 3,924 Likes on 1,872 Posts
Bill,
I recently tore my door mechanism apart because it was very sloppy. When I did I was surprised to find that the door handle shafts had very little wear. I couldn't say the same for everything else though. The little cam with the square hole that the handle fits into was very worn as well as the pawl, the piece the pawl pushes, etc, etc, etc.
By adding material here and there by doing a bunch of small spot welds and then filing things back into shape I was able to take approx. 90% of the slop out of the mechanism.
There are some pictures of the various parts in this thread;
https://www.ford-trucks.com/forums/1...le-repair.html
Bobby
Old 03-27-2015, 07:04 PM
tractormanbill
tractorman
Bobby,
I read your tech article yesterday but my problem is a wobbly handle pin. I haven't tore into one yet but I suspect there is a bushing in the housing that supports the shaft.
Since you have had one apart do you know?
Think you were out of town when I came through Rio Rancho last summer but I stopped by Ross's place.
TractormanBill
Old 03-27-2015, 09:34 PM
bobbytnm's Avatar
bobbytnm
Yea, we missed each other last time around. I do travel a lot for work.
There is no bushing that the square shaft goes through. It goes straight into that funky pawl shaped doo-dad with the square hole. That pawl piece with the square hole has a shoulder on it that fits into a corresponding hole.
I don't know much about the other end of the square shaft...the end that connects to the handle itself. I have a couple laying on the bench. I'll try to remember to have a look at them tomorrow.
Bobby
dadgonebroke
20
07-08-2017 09:49 AM
zippi
1947 and Older Ford Trucks
05-21-2017 08:55 AM
calicofiftyseven
07-23-2009 04:36 PM
Matt Scassero
09-14-2004 09:58 PM
Quick Reply: Suggestions needed for door handle shaft repair
