Suggestions needed for door handle shaft repair
Bill,
I recently tore my door mechanism apart because it was very sloppy. When I did I was surprised to find that the door handle shafts had very little wear. I couldn't say the same for everything else though. The little cam with the square hole that the handle fits into was very worn as well as the pawl, the piece the pawl pushes, etc, etc, etc.
By adding material here and there by doing a bunch of small spot welds and then filing things back into shape I was able to take approx. 90% of the slop out of the mechanism.
There are some pictures of the various parts in this thread;
https://www.ford-trucks.com/forums/1...le-repair.html
Bobby
Bobby
Bobby,
I read your tech article yesterday but my problem is a wobbly handle pin. I haven't tore into one yet but I suspect there is a bushing in the housing that supports the shaft.
Since you have had one apart do you know?
Think you were out of town when I came through Rio Rancho last summer but I stopped by Ross's place.
TractormanBill
TractormanBill
Yea, we missed each other last time around. I do travel a lot for work.
There is no bushing that the square shaft goes through. It goes straight into that funky pawl shaped doo-dad with the square hole. That pawl piece with the square hole has a shoulder on it that fits into a corresponding hole.
I don't know much about the other end of the square shaft...the end that connects to the handle itself. I have a couple laying on the bench. I'll try to remember to have a look at them tomorrow.
Bobby
Bobby
dadgonebroke
20
07-08-2017 09:49 AM
calicofiftyseven
07-23-2009 04:36 PM
Matt Scassero
09-14-2004 09:58 PM
