I'm interest in biodiesel , would anyone know about that ????
A handful of years ago I looked into it a little when I had an 84 Benz diesel wagon. The chemical process for making it made me shy away from it. That and the idea of driving around for waste veg oil.
http://www.make-biodiesel.org/Featur...tutorials.html - some reading materials
I have ran 100% bio in my 99 and 03 powerstroke with no issues. You need to start small, like 20% bio and 80% diesel, and then increase the blend a little at a time. biodiesel will clean all the crap that diesel has left behind over the years so if you go to strong to fast you will plug filters or worse. The only thing I noticed with running B100 was quieter running engine. Lubricity is increased and exhaust smells better. Yes bio will absorb moisture if you leave it lay around in an open container. That moisture will also fall to the bottom though. That's just my .02
I'm a chemist....the chemical process seems really straight forward to me once you have the equipment set up, but I'm retarded when it comes to wiring/plumbing so I haven't tried making the equipment. If I remember correctly, it is simply a matter of mixing oil with the correct amount of sodium hydroxide (Lye) and heating it. The oil separates into two phases (like oil & water). You put one phase in your truck, the other is discarded.
Mother earth news did an article on how to convert an old water heater into a bio-diesel maker. I'd love to see a rig that somebody made on here.
How to Build a Single Tank Biodiesel Processor: 4 Steps
Apparently the third ingredient is alcohol. A little for the diesel, a little for the mechanic
What specific questions do you have. Yes there are different ratios you can use. it depends on the ffa and the moisture content of the oil. The higher the ffa, the more caustic you are going to use to react it. Check out the links everyone has put on here and PM me if you have any more questions. in the past 8 years I've produced about 40 million gallons.
