There should be some threads on this. But any column from a 73-79 f100-f350 will work but note that the interior trim and base where steering wheel mounts and the wheels are different on the 78-79's. also if you get a two wheel drive column you can disassemble the column and remove the shaft and swap it with a 4wd one. That is if its a none tilt column. One of the hardest to find columns is a manual tilt. Which I believe only came in 78 & 79.
but note that the interior trim and base where steering wheel mounts and the wheels are different on the 78-79's..... what exactly does this mean? as long as it goes in without any mods im happy...
Here hopefully these will explain a little better. This is a 79 auto 4x4 tilt column in a 1976 f250 note the red piece that is along the dash is from the 76 column once I find a good 79 one which is bigger around and black plastic ill switch it out. Hope it helps.
