Trans Running Too Cool?
I've read some stuff on the internet (must be true, right) about having a transmission running too cool and not being able to burn off excess internal moisture. Some say its almost as bad as running it too hot. When I installed my TruCool Max and SD cooler lines, this wasn't an issue I considered.
My trans runs around 130 degrees on a "not hot" day, when I'm straight driving. Get a little more heat and humidity out there, plus some stop/go traffic, I can reach 150. On a hot day, with a loaded trailer, I'm hard-pressed to see 170-180. In fact, I don't think its been over 180 at any point after the mods.
Should I be concerned about this, or perhaps trying to find a way to ramp up the operating temps a little bit?
Thanks all. I tend not to worry about it, but a sanity check is always nice. Agreed that heat is the biggest enemy to a tranny, which is why I installed the cooler and SD lines. Pulling my travel trailer in the middle of the summer saw the temps climbing to 230 or so, which was alarming, so thus came the cooler. Last October, we pulled it to the north GA mountains and never even reached 150 on the trip there.
IIRC, the SD lines are overall 1/16" larger diameter than the stock lines. Doesn't seem like that alone would make a significant difference. I installed them at the same time I did the cooler, cooler line bypass fitting and trans fluid change. The biggest difference has got to be from the cooler itself, but at the time I was going all-in for a cooler running trans.
(Photos courtesy of Cary @ CT Performance)
with my Large 6.0 tranny cooler ,i rarely see 170 pulling hard,thats ac blasting ,pulling the 30' camper, bed loaded with firewood and a golfcart on top of the wood.If I could just get my EGT's down now.Need up pipes I guess.
35k miles on fresh tranny rebuild with the larger cooler,no probs yet running lower temps.
timmosazz
08-09-2006 08:10 AM
Atom
09-28-2004 06:40 PM
