Spark plugs lighting up
I will check the connections and grounds tonight . Is there any particular grounds I should focus on ? The boots look fine no burns or scorching , Though one did have a bit of soot ? Thanks guys I'll keep trying .
No not that I can tell . They look pretty good . The ceramic part of the plug that's not covered by the boots are a bit tanned . I took the ignition system apart and cleaned all the connections , rechecked the gaps and firing order , re routed the wires to lessen the chance of cross fire and checked and cleaned up the ground wires . Fired it up and nothing's changed . From searching I keep hearing that running lean can cause this though I don't know how ?
Some good points here.
Check your spark plug gaps to make sure they're not too wide.
After installing the plugs, spray them down with some brake cleaner to strip off any dirt or oil.
Wipe the plug wire rubber boots clean and then use a light smear of silicone grease inside each boot. They sell little packs of the grease for $1 at the auto parts store, or maybe you have some for plumbing already.
I don't think carbon deposits from the leaking exhaust are likely to be the cause. The boots should cover enough of the insulator to keep it clean and prevent arcing.
Good luck!
Good luck!
on
I'm wondering if perhaps he has too MUCH dielectric grease- and it is contacting the center contact, & providing a path... Dielectric properties allow it to conduct electricity: IF it is overloaded, maybe that is allowing the spark to travel- if it not a wire issue...
Wipe them dry, and apply IAW the instructions in this link: 1983 Ford Bronco TSBs & FSAs (Recalls) for '83-96 Broncos & F150s picture | SuperMotors.net
It does state NOT to get any on the center conductor...
Scott
Scott
They also sell really big tubes for about $2.50 (or maybe it's $4.99, I'm just guessing). Regardless, it's a WAY better deal then the "single-use" packets.
You should be fine just wiping with some paper towels. What you don't want is any going up into the metal clip area, but even that would not be a disaster - just use a Q-tip to wipe it out.
Just use your pinky finger to smear a thin film around the end where the rubber seals to the body of the plug.
For what it's worth, LOTS of old engines used spark plugs where the high tension wires attached with screws and metal was completely exposed - no rubber boots covering them.
I'm guilty of getting off into the brush trying to troubleshoot remotely too - but let's back up a bit.
Three different sets of wires - same problem, something else is the culprit. A dab of dielectric about the size of a pea is about right, but it's not going to be an issue?
The high tension voltage will always find the path of least resistance. The idea of course is to make the spark plug gap that path. Too wide a spark plug gap would do it, or the wrong plugs, fouled out, worn out. Or too lean of a mixture.
#28
I will clean the boots and stuff . But I'm betting it's a lean condition or something . It's hard to diagnose without any codes appearing . And if my exhaust manifold leak is the culprit you'd think the computer would fatten the mixture due to the O2 sensor reading lean ? I just replaced my fpr to see if that would help . Maybe I have a vacuum leak ? I'll check it out and see what I can find . I know my egr has been on my mind this whole time but not sure why lol
#30
NGK wires are top flight in my book. Have used them on many motorcycle and car engines with never a peep. Can't believe there's any problem with the new MSD wires either. Even the old ones were probably ok, but maybe too high a resistance to provide a hot spark.
The new Motorcraft plugs were probably gapped acceptably from the factory. That's modern manufacturing for you.
Here's an idea: Wait till dark, start that engine, then film it with your cell phone and post it for us to see.
