Ford van with Toyota DNA??
Hello all, kinda silly and a bit of a mystery to me but i know someone out there has a simple answer. I was drilling out the lower rear driverside rocker panel with a hole saw on my 04 e350 extended van for an ac port plug when i noticed something unusual. When i popped out the hole saw cutout, I noticed this sticker. Keep in mind, this is from the inside of the hollow sealed rocker panel.
Anyway, i did say it was kinda silly at first but it was an interesting find. I did also state that i could be wrong about sheet metal work.. just never seen that before...
I'd say rust repair; looks like paint flaking behind the bumper. If I could see the van I could "feel" if bodywork had been done. Overspray in the wheel well or on the underbody? Signs of welding? Pass a magnet over some of the metal and see if it's loaded with bondo? Feel the lip around the rear wheel well for signs of filler or grafted metal.
I guess it's interesting but it's clearly not something that Ford did in 2004. Do you have a Carfax on the van to see if it's been in a wreck? Although I'd be more suspicious of rust repairs in that area.
The bottom edge of my '02 van is covered with polyurethane chip-resistant paint. Is your van covered with that stuff all the way around?
I wouldn't take Mark's comment as any kind of an insult. It's obvious that your van is a hack job done by someone...and that would not be the Ford plant where it was built.
George
George
I'd say rust repair; looks like paint flaking behind the bumper. If I could see the van I could "feel" if bodywork had been done. Overspray? Signs of welding? Pass a magnet over some of the metal and see if it's loaded with bondo?
George
George
Was only insulted by Marks comment because someone from Florida is trying to sell the Brooklyn Bridge to a New Yorker.
Wanna bet that slug was simply left over from another job previously performed with the hole saw making the current opening for the shore power connector?
I've forgotten to remove those slugs from hole saws many a time only to discover them when the saw was to be used again.
I'd remove the connector and insert a bore scope or inspection camera inside that cavity--see what else was left behind.
One way to almost be certain if body work was performed is removing that sides tail light assembly---typically body shops don't remove those unless its absolutely necessary. In the event it was removed before paint there very well might be evidence of over spray or maybe the pig tail leads for the lamp sockets will show paint evidence.
As for Mr Kovolsky's excess bridges in his current inventory----I hear Obama's looking to rebuild our national infrastructure...........sales opportunity?
Toyota sticker a miracle? Maybe a gold brick, a winning lotto ticket or my missing car keys.. That would be somewhat of a miracle.. Im gonna drill the other side out and see whats in there..
gdub
22
04-12-2012 10:24 PM
