Any ideas
Any ideas
I have a 1994 bronco with the 351 efi in it.. It has stalled and not restarted 3 to 4 times. it turned over fine has spark and fuel pressure to the nipple on the rail. I had a shop replace the comp it then ran for about 5 miles and now back to the same problem. Any idea's I'm not sure where to go next without taking it to a dealer.
Given that ECM failure represents about .001% of the causes for engine malfunction, I would second gatorfor88's suggestion to pull Codes (you can run a KOEO test at least). IF you get Codes 14 or 211 (you will get either two-digit or three-digit Codes not both) then consider g_k50's suggestion. The Profile Ignition Pickup is buried inside the dizzy. You have to tear it down to replace it.
