2011 F150 oil life
2011 F150 oil life
New guy here. I bought an 2011 F150 a few months back with 45,000ish miles on it. Around 48,000ish miles the truck told me I needed an oil change. I put Quaker state 10w30 full synthetic in. At 53,000ish the truck said I need another oil change. I am approaching 58,000 and according to the vehicle report I only have 27% oil life left. Everything I have read online says that the computers are set to get 10,000 miles on an oil change. Can someone offer some suggestions? thanks for the help
I'll let someone with 5.0 knowledge answer- but in the EB, it's best to keep the changes around 5000 miles with full syn, due to the direct injection fuel system. But as a suggestion, you might look into pulling a sample for Blackstone and see what they have to say. I'm one to go with a 5k OCI unless there is good reason (Blackstone report or similar) to extend. I used to run 7500 OCIs on my 7.3L diesel, but that was because I was running full syn and Blackstone showed good oil still at those mileages. I could've gone to 10, but never felt comfortable going out that far.
cdorr0 ... Everything I have read online says that the computers are set to get 10,000 miles on an oil change.
- drives - long haul | short trip.
- towing.
- severe service | normal.
- extended idling.
- driving style.
- oil used.
etc., etc., etc..
-click- the pic'
Goth 150
< This space intentionally -blank- >
the type of oil you use will have no bearing on how the algorithm calculates your Oil Change Interval (OCI).
the 2011's use a fairly complex algorithm to calculate your oil life based on the actual conditions the vehicle sees in use.
if it is telling you to change your oil at 5,000 miles it is because you need an oil change.
full synthetics or boutique oils (amsoil, redline, ect) can add a degree of buffer so that the oil isn't actually "used up" when the Intelligent Oil Life Meter (IOLM) says it is ..... but that puts you back to square one as far as knowing what your OCI should be.
if it were my truck, I'd use what ever oil you feel most comfortable with (brand) of the correct grade (5w20) and change it when the IOLM says it needs changed. to prove that the IOLM isn't wasting your money, you could do an oil analysis to verify, but from what I've seen the IOLM correlates very well with actual life left in the oil.
short trips are harder on oil than long trips, so the OCI on a vehicle that sees substantial short trips will be much shorter than one that sees a lot of highway miles.
2013 with a 5.0 and I've been using Blackstone to analyze my oil. Using full synthetic (I'll leave the brand name out) and not commuting to work, just mostly highway and some day trips into town (20 miles each way) the oil can stay in over 10K miles.
Drop it out early or use and analysis if you're interested in going farther. You don't need to analyze it each time, just enough to figure out how far it can go.
