Steering Questions
Steering Questions
I own a 1995 F150 4x4 that is lifted 4 inches and my steering is a bit questionable and old right now. I was wondering if anyone knew whether it would be better to replace all the Tie-Rods and such, or to get a whole new steering system. My second question is what is the best aftermarket steering setup out there for this truck?
Steering Questions
No. You put a dropped pitman arm on the shaft that comes out of the steering box. I have the superlift superrunner steering also. However, you can only put the steering on superlift's lift kit. I however, got a skyjacker lift kit, and welded the special bracket on from the steering system. Go to superlift.com for information about the system.
Steering Questions
Isn't anything special about the pitman arm, I'm using the skyjacker one because it came in the skyjacker kit (don't need to be buying two haha). I have the skyjacker axle pivot drop brackets and with a little creativity I got the superlift steering on it. I took a 1/4" piece of flat stock and welded it to the crossmember and the drop bracket. Then I welded the steering bracket onto the flat stock and mounted it up. Pretty simple. The skyjacker lift kit is much better than the superlift kit (i've had both) and I didn't want to get the superlift crap so I welded it on the skyjacker stuff.
https://www.ford-trucks.com/forums/s...hreadid=100828
