no brake lights
no brake lights
My # 13 fuse keeps blowing each time I push on the brakes. All other lights work. I unplugged the two plugs at the rear bumper. It blows the fuse, when I push on the brakes.
I tried unplugged the plug at the bottom of the steering column, with the green wire. The fuse didn't blow. The two rear plugs are still unplugged.
I unplugged the two plugs at the bottom of the column, the multifunction switch and the two plugs at the rear bumper. While I pushed on the brake pedal this time the High Beam On indicator, came on. My lights were not turned on and the key was not in the ignition. Fuse 13 didn't blow when I pressed on the brake.
Also I read the most common issue was the plug to the master cylinder leaking into the plug. Mine was ok. What should I check next?
Benjamin04
Electrical Systems/Wiring
05-07-2013 02:48 PM
