Fuel leak
Old 03-09-2015, 08:54 AM
big-head's Avatar
big-head
big-head is offline
Fuel leak
I'm dripping fuel on top of the engine at the fuel filter . Where the line ties into the filter canister , there is a small plate that's attached with small Allen screws its dripping between this plate and the canister .... I assume there is a gasket/oring that is causing it ...... What is the part number or correct description so I can go to ford dealer and get one. Thanks.
2007 Ford 4X4. 6.0 diesel
Old 03-09-2015, 09:01 AM
Iaff113's Avatar
Iaff113
Iaff113 is offline
Originally Posted by big-head
I'm dripping fuel on top of the engine at the fuel filter . Where the line ties into the filter canister , there is a small plate that's attached with small Allen screws its dripping between this plate and the canister .... I assume there is a gasket/oring that is causing it ...... What is the part number or correct description so I can go to ford dealer and get one. Thanks. 2007 Ford 4X4. 6.0 diesel
Order a blue spring kit from any place online or get the updated kit from ford. And replace the spring and everything while you have it off. It's a simple job
Old 03-09-2015, 09:25 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
Click this link for a write-up from the Tech Folder .
https://www.ford-trucks.com/forums/1...ue-spring.html
Here's a pic of the full kit.
Old 03-09-2015, 11:32 AM
big-head's Avatar
big-head
big-head is offline
Thanks
Thanks guys. Just the oring is 3C3Z-9C065-AA for $5.32. The whole kit is tons more. Oring is all I should need right.
Old 03-09-2015, 11:44 AM
Iaff113's Avatar
Iaff113
Iaff113 is offline
Have you updated the spring already?
Old 03-09-2015, 11:50 AM
big-head's Avatar
big-head
big-head is offline
No I have not. 127,000 miles. Can I get just the spring ??
Old 03-09-2015, 11:52 AM
Iaff113's Avatar
Iaff113
Iaff113 is offline
Not sure I just bought the kit for 40 bucks and replaced it all
Old 03-09-2015, 12:17 PM
big-head's Avatar
big-head
big-head is offline
I put a entire kit in it. All fixed
Thanks Guys
Old 03-09-2015, 12:25 PM
Iaff113's Avatar
Iaff113
Iaff113 is offline
Great thanks
Got mine from riffraff if you are interested in buying the kit
Old 03-09-2015, 01:11 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
weekendwarriorfsw32 is offline
Master of Strokes
Old 03-09-2015, 05:44 PM
big-head's Avatar
big-head
big-head is offline
Thanks guys. I put a full kit in her. Appreciate all the replies.
big-head
03-12-2015 09:33 PM
big-head
6.4L Power Stroke Diesel
03-09-2015 11:45 AM
pkins
03-17-2010 10:18 AM
89BlackBeauty
05-12-2009 08:27 PM
phish555
01-28-2009 09:57 PM
Quick Reply: Fuel leak
