3 part question re: 3 point seat belts
Old 03-07-2015, 10:06 AM
RJNRJN's Avatar
RJNRJN
RJNRJN is offline
I have 2 point, I want 3 point.
1) how to install something to hold the part of the seatbelt that hooks to the cab (called pillar & Pillar loop? not sure)
2) are the 3 point seatbelts on ebay for $30 to $50 satisfactory?
3) probably far into the future I want to go from bench seat to buckets, will that require new seat belts?
Old 03-07-2015, 10:58 AM
ZOOT's Avatar
ZOOT
ZOOT is offline
IMHO 3 points are better than 2. Mounting is easy. You have to weld a piece of stock for the one next to the door for the best installation. Juliano's is where I got mine and am very happy with them. I went to bucket seats and they had exactly what I needed with good instructions and hardware. This isn't something to get on the cheap. (ebay mystery parts).
Old 03-07-2015, 01:32 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
It would be really helpful in answering your questions if we knew what year and model your truck is.
48 -52 Classic Haulers has the upper plates to weld into the cab.
48-50 - p/n 2180-4850
Search - Classic Haulers F-1 Parts
51-52 - p/n 2180-5152
Call them 877-252-1948.
Go online and order their free catalog. classic-haulers.com
Old 03-07-2015, 01:53 PM
mustangmike6996's Avatar
mustangmike6996
mustangmike6996 is offline
I was just thinking about this last night.
Old 03-07-2015, 02:04 PM
RJNRJN's Avatar
RJNRJN
RJNRJN is offline
Sorry '52 F1
I don't mind giving Haulers $100 for that funky lookin thing and Juliano's $200, if it's the smartest thing, I'm wondering if it's necessary, the best value.
Old 03-07-2015, 03:59 PM
Jolly Roger Joe
Sorry '52 F1
I don't know anything about Juliano's, but I have those from Classic Haulers in my truck and I'm very happy with them. I also bought my belts/retractors from them (they were shipped from Mid Fifty) but you can find junk yard belts that will work and are a lot cheaper. I wanted new ones.
Old 03-07-2015, 04:25 PM
RJNRJN's Avatar
RJNRJN
RJNRJN is offline
Great picks Joe. Are those upper mounts from Haulers welded in? Haulers Lists them as 1948 to 1950, did you have to modify for your '51?
Old 03-07-2015, 04:43 PM
Jolly Roger Joe
Yes, they are welded in.
Classic Haulers sells them for the 48-50 trucks with the smaller window (bigger plates) and for the 51-52 like those in the pics.
Old 03-07-2015, 06:11 PM
JPMallory's Avatar
JPMallory
JPMallory is offline
Your experience may vary. I ordered the 51-52 brackets, (my 48 has the 51-52 rear window) and received the 48-50 brackets. I emailed about it and was told that I will need to cut them to fit.
Not really a big deal. Just odd that they have two different part numbers.
Old 03-07-2015, 07:01 PM
Jolly Roger Joe
They are definitely two different parts. I did not have to cut mine (51-52) and they fit fine.
You got the wrong parts. The pics online show the 48-50 plates are MUCH wider than mine. Probably 10" wider.
48-50
51-52
Old 03-07-2015, 07:30 PM
larryb346's Avatar
larryb346
larryb346 is offline
I used the belts and the upper attach bolt point from a 98 ford pick up. It didn't require much fabrication to make it all work. Bent a upper plate to fit then welded the upper attaching nut to it then to the window and door frame.
The lower points to the floor and the retract/lock up to the rear floor near the rear wall. really not difficult to do if you have any fabrication skill
Larry
Old 03-08-2015, 12:17 AM
das54's Avatar
das54
das54 is offline
I made plates for my 54 and got belts out of the back seat of a Ford minivan. The belts from the 3rd seat in minivans is not used much and I think the single retractor/inertial brake unit is much easier to install than the double ended units.
seat belts 010 - anchor point for the passenger side upper shoulder strap loop
seat belts 005 - belts came out of the back seat of a Aerostar van, single inertia type spool with belts that are plenty long and mounted in the original vehicle very close to same orientation as the truck cab.
Old 03-09-2015, 07:07 PM
RJNRJN's Avatar
RJNRJN
RJNRJN is offline
Great pics, great details. Thx
Old 03-21-2016, 10:31 AM
Fyrhosr's Avatar
Fyrhosr
Fyrhosr is offline
Does anyone have pictures of the finished product in a 51? I am looking at the mid fifty product, curious where to mount the lower part of the extractor portion of the seatbelt (point closest to the bottom of the doors). Thanks
Old 03-21-2016, 02:57 PM
schoo's Avatar
schoo
schoo is offline
I got my belts from sportsmans(army surplus) less than $30 had to make my own mounting brackets not a big deal though
mailto:SportsmansGuideSpecials@sportsmansguide.com
Amphihauler
09-12-2017 03:48 PM
FlagshipOne
05-27-2016 08:14 AM
Cat906
2009 - 2014 F150
11-18-2014 10:10 PM
Doc
15
06-27-2012 10:10 PM
patrickke
1999 to 2016 Super Duty
12-16-2009 02:32 PM
Quick Reply: 3 part question re: 3 point seat belts
