multiple degas bottles cracking
Has anyone else experienced degas bottles cracking? I have been through at least 2 napa and 2 ford in 2 years. all of them have failed along a reinforcement rib on the bottom above the outlet. new caps at the same time on all of them. never puked. the napa ones failed within months of each other. the ford one that just failed was replaced with a napa one again which lasted 2 months.
again NEVER had a puke.
thanks
thanks
I would think if the Napa one's are failing at that rate is there is a defect in the manufacturing process that is causing them to leak
If your having that much bad luck with them I would avoid them and either use Ford ones or find a different vendor to but them from ( You would have to watch out that the next one you buy isn't who manufactured them for napa )
But that is brutal, but at least napa is giving you replacements, but if the replacements arent holding up, then I would just get my cash back and look for some where else for a different one.
went thru a couple of ford ones as well. if this napa one fails, I will be getting an aluminum one off ebay. the down time I have in this to go get a new one and change it out each time will have paid for one already.
