Do you guys epoxy prime E-coat aftermarket parts......
Do you guys epoxy primer EVERYTHING including new aftermarket stuff?
Or just the old treated cleaned metal?
If you coat the aftermarket ecoated parts, do you completely strip them to apply the epoxy or just scuff them and go over top?
I just bought a qt of epoxy primer to use on the rear axle Im working on. I stripped to bare metal, now Ill degrease again then primer. I kind of learned my lesson wasting so much money on rattle can paint. Now that I have the equipment to paint I try to use it. EDIT When you say everything, Patch panels, tranny cover, sheet metal etc, yes, nuts and bolts no. Also I do clean and prep new bare metal to remove any shipping coatings that may have been applied. Sorry for the choppy answer, I misread your question the first time I read it.
Test the e-coat by wiping down with lacquer thinner. If it comes off, strip it. Some of the older stuff will. When you do your final sand, do the e-coated panels at the same time. This will insure equal mechanical adhesion. I've seen too many e-coated panels that peeled after a few years due to improper "scuffing". Too much time and effort in painting a vehicle to short cut anything.
If it comes E-coated I leave it and clean it then prime with a 2k and paint (base/clear coat)
If it is bare metal I will clean and scuff then prime with Self etching primer.
It seems that I hear a lot of older guys completely strip and reprime all parts but new guys say it isnt needed. Technology and quality have made some repop parts that are better than original factory coatings so there shouldnt be a need to strip it down.
