Rear crewcab door electrical problems
I remember reading a thread about this earlier but I don't seem to be able to find it using the search engine. My 95 crew cab has power windows. When I got the truck, the windows were completely inoperative. I removed the old door window motors and found they were inoperative. I installed new window motors and when connected to a battery, they run the rear windows up and down just fine. I also inspected all the wiring in the door itself and found no problems.
However, when I attempt to raise or lower the rear windows via the driver's door switches, I run into problems. Neither window will go down or up on commands. If I attempt to operate the passenger side rear window nothing happens (and no voltage gets to the motor). If I attempt to use the driver's rear window, all the lights dim and the radio shuts off for a second. No significant voltage gets to the motor in this case, nor does the window move. Also, neither rear window switch seems to be operative.
This seems to indicate to me that I have a couple of cuts and a short somewhere. I had read that this was a common problem with crew cabs and that there was a point in the harness after it had entered the cab from the door where this commonly happened. Where is this point, and how do I get access to it? Any other tips would be appreciated.
Stevaroo01
09-22-2017 06:21 PM
MUSKRATT2
12-16-2009 09:38 AM
