whining noise
You can here it from the outside?? Is your truck a '13 or above?? If yes to these, it is a different pump under the hood. It is a pump whine, which one, we are not sure and neither are the techs, because they now notice it too. The '11s and '12s do not do this. All of our newer med units and my '13 does it.
Mine is an '11. I can hear it outside and after some troubleshooting I think it is probably the fuel pump in the tank. I am going to try changing the filters and see if that makes any difference. It has been extremely cold hear in western ny so that could have something to do with it as well.
Mine occasionally makes the same whining noise as in the video. Seems to only do it on hot idle. Seems to goes away as soon as you raise the RPM slightly. I don't recall it making this noise prior to changing the fuel filters. I'd be interested in what others have found with regards to this.
If the frame mounted fuel filter leaks air around the threads, you will experience an additional pump running. It is very noticeable, electric motor whine type noise. If the leak is bad enough, you will later experience "Low Fuel Pressure" warning. One simple thing you can do short of changing both fuel filters is to make sure the frame mounted fuel filter is screwed in all the way to the stop. Unscrew half turn and then screw back in until you feel a positive stop.
caprisecca
1999 to 2016 Super Duty
06-28-2013 02:47 PM
