same bolt pattern,, but if i remember right the 92 and older center hole is smaller after 92 the center hole is bigger,, it was because the 4x4 wheels had bigger center holes after 92 ford made all the center holes bigger,,, i have come across several stock rims that would not fit the center hole but bolt patterns were the same,,,,,,,,,,
