Sponsored by: Kumho
Measuring Bolt Pattern
Old Mar 3, 2003 | 12:44 PM
KJKozak2's Avatar
KJKozak2
Greetings all,
I just picked up some 15x10 steel spoke rims and they have the worng bolt pattern for my truck. They have 8 holes and I was told they came off of a heavy duty Dana 44 from a 77 high boy.
I would like to trade them for the same rims with 5 on 5 1/2 bolt pattern.
How do I measure the bolt pattern on an 8 bolt rim? Is it every other hole like a 5 bolt?
I just want to be sure I describe them right so someone doesn't make the same mistake I did.
Thanks in advance!
Kevin K.
Old Mar 3, 2003 | 06:08 PM
theGman's Avatar
theGman
8 bolt is straight across, center to center.
same with 4 and 6 bolt.
5 bolt is from the center of one to the far end of one which is 2 bolts down, not the very next one.
Old Mar 4, 2003 | 08:34 AM
KJKozak2's Avatar
KJKozak2
Thanks! That helps.
Does anyone know if the 8-bolt pattern in the same on a 77 hi-boy and the dana 60 axles?
I'm not familiar at all with those.
Thanks!
Kevin K.
