1966 - 1977 Early Broncos
Need Disc Brakes on my 1969 Bronco, what can I use?
Old 02-27-2015, 05:59 PM
mecone's Avatar
mecone
mecone is offline
Looking to buy a complete setup for disc brakes to mount on my 1969 Bronco front end
Im in ElSegundo by LAX
Old 02-27-2015, 07:39 PM
77&79F250's Avatar
77&79F250
77&79F250 is online now
Received 3,352 Likes on 2,494 Posts
Old 03-01-2015, 05:25 PM
shadetreebronco's Avatar
shadetreebronco
shadetreebronco is offline
A Dana 44 from a 76-77 Bronco has factory disc brakes but the steering linkage is the inverted "Y" type and does cause the tires to toe in and out a bit with heavy suspension travel , also the tie rod ends end up very close to some rims.
I have this set up on my 75 , I am limited on what i can use for rims.
If I was to do it again i should have installed the knuckles from a F150 or 78-79 bronco Dana 44 , the knuckles have larger tie rods , stay away from rims and there are more steering linkage options.
There are also a few aftermarket Dana 44 knuckles out there as long as you have a Early bronco Dana 44 housing. Some full size Dana 44's have been narrowed also.
Hope this helps.
Old 05-23-2015, 09:18 AM
4drf350's Avatar
4drf350
4drf350 is offline
brakes
Hi I just did it the fans 30 knuckles will fit the fans 44 spindle . I went to the salvage yards around here I am using Chevy spindles an Chevy backing plate an Chevy calaper with ford rotor.
The parts are from the 70's an 80's trucks
Old 04-10-2016, 10:39 AM
tinker934's Avatar
tinker934
tinker934 is offline
Help
I have a 70 bronco with a Dana 30 can I get a better breakdown of the kid you used for yours and what parts from what years because I too want to do a disc brake conversion in front
Old 04-10-2016, 09:19 PM
Nothing Special's Avatar
Nothing Special
Nothing Special is offline
I bought a kit when I did mine. I don't recall if it was from Jeff's Bronco Graveyard or Wild Horses (I've used both and it was a while ago). So it came with pretty much everything all together.
If you're trying to piecemeal your own kit, the trick is to get the right mix of Ford and Chevy parts. I think it's the stock Ford knuckle, a Chevy caliper bracket, caliper and pads, Ford spindle and Ford hub. I don't recall if it's a stock Ford disk or if that's a special part.
But emphasis on the "I think" part.
edit: according to dclack (below) I'm wrong about the spindle, you need a small bearing Chevy spindle. And he says you do use a stock Ford rotor. As I said, I wasn't sure about my info, so I'd go with his corrections.
Old 04-11-2016, 07:38 AM
chrlsful's Avatar
chrlsful
chrlsful is offline
'76/7 TRO, swap knucks, back spacing, F150 ster linkage
Hope this helps.
I used '80s el derado rear calipers (wanted to keep e-brake), stock car brackets, CJ rotor. Not sure if that's the Q.
Sounds like ur well ahead of me in the frnt.
I have the same set up and am in process of total mod there:
Wanna go TRO, earlier 'T' or F150 steering linkage, knuckles, 1 tun axles/u-joints, and F150 shock bucket/1 Bilstein per 4 corners. Am not a mechanic but wish to try to figure the sequence of operation to complete this swap. I guess I should try to do it all at once. I've had the older T stuff modded to a F150 style (machinist put 2 or 3 more adj sleeves on). So have started...
Old 04-13-2016, 03:34 PM
dclack's Avatar
dclack
dclack is offline
For a Dana 30, your only option is the so called Chevy conversion. You need the caliper, backing plate/bracket, AND spindle from a Chevy D44. The spindle must be from a small bearing D44; they started making a large bearing at some point (I don't remember the year) and it won't work. Then use a hub and rotor from any Ford D44, even the TTB.
Here's the Classic Bronco.com links:
Classic Broncos .com - Tech: Disc Brake Conversion * 66-77 Early Ford Broncos
Chevy Disc Brake Conversion | ClassicBroncos.com Tech Articles
Rizzo66_82
01-03-2009 07:42 PM
burnham
22
08-06-2005 07:33 PM
ramboss429
06-17-2004 03:35 PM
Fordboy 72 F-100 4x4
01-11-2004 10:43 AM
12-25-2003 10:57 PM
Quick Reply: Need Disc Brakes on my 1969 Bronco, what can I use?
