Lower ECT, lost heat, and puked!!!
If you lost enough coolant to make your heater blow cold, I would pull the egr valve and look at the condition of your intake manifold. If it is wet, you probably have a bad egr cooler. It should be dry and kind of ashy. I had that problem and my intake manifold had coolant in it. Did an egr delete and all problems seem to be solved.
Well just got home. Drove 70 all the way home. Released any pressure before I left work. Heater tried to blow cold at one stop but went back to normal when I started moving and stayed fine after that. Temps stayed perfect all the way 200 ect 206 eot although it did seem like the eot took longer to get up then normal. Got home and hoses were tight. I released the pressure and coolant was still about normal. It did appear to puke a tad on the top only and the cap was pressurized normally. This is an interesting one.
2006 F350 4X4
2006 F350 4X4
read this for the no heat...https://www.ford-trucks.com/forums/1364567-no-heat.html
I think your overly worried, seems your waiting until the truck blows up to say... I knew it, relax.
2006 F350 4X4
My mind had thought about that. Although it's not warm out the fact it wasn't overheating had me on the fence about it. I would say if the pump is toast and didn't overheat that makes these engines even more awesome then I thought before (60 miles today at 60 to 75mph)
2006 F350 4X4
2006 F350 4X4
2006 F350 4X4
During the recent cold snap... my mishi 200 when I stop at lights cools down to 196-198 all the time. Get going, back to 200-204 and my EOT doesn't move as fast, stays around 204 all the time and it's slower to cool because it's thick. I think you may have a blend door issue. The puking may be something all together different. Puking coolant is a pressure thing as in head gasket thing, add a gauge to the line to be sure of how much pressure.
Lastly, not long after I changed my stat, mine puked to the bottom of the degas bottle. Filled it to min line and been steady since.
I got a feeling you got the same problem I have. I haven't done the tests yet but I think my EGR cooler is slightly cracked and lets in gases when it gets really cold forming a gas pocket in the system.......I just ordered a IPR EGR delete kit and a oil cooler plus some other goodies. I doubt it's the head gaskets but we shall see after the delete is in
#28
2006 F350 4X4
#29
are you heater core hoses about the same temp? after the truck is warmed up feel each hose going to the heater core. I had my heater core block up and it acted a lot like yours. come to a stop and cold air. start moving and heat comes back. eventually I lost all heat and had to replace the heater core.
