1973-1979 F150 vs 1987-1996 F150
So im turning 16 pretty soon and decided i need a truck so i can earn my own money over the summer. I plan to do a little 4x4ing with my buddies and not a whole lot of commuting. Do you think the newer body style truck or the older would serve me well. Ive always thought the 1973-79 were a better looking truck.
Both body styles will serve you well. I have owned both and can say that I loved my 83 supercab with 351W/3spd w/overdrive. However, depending on where you live, your choice may be dependent on smog rules. Here in California, pre-76 are the choice of the day. If you lean towards dents, specifically, buy one. You won't regret it. When a man/boy owns his first truck, he will never be without a truck again.
on
My vote is for the older dent, because they look better, but stuff a more modern EFI engine in it from a '96. The '96 EFI setups were an interesting phase, with OBD II and Mass Airflow Sensors, but older design engines. I stuffed mostly '96 4.9L engine, fuel lines, and fuel tanks into my '78, and have been very happy with it.
I also wanted a 67-79 Ford for my 16th. I turned down dads 99 and ended up buying it years down the road. I got my 78' like i asked for and I don't regret that. I have my 90 bronco now too and it usually runs, but if it does go down I'm clueless on the electrical issues. My 78 I can fix it.
I like my bronco, but i vote for the dent also.
i'm 17 and i have a 73 f100 2wd 390 C6, but would trade up to a 87-91 f150( if it had all the stuff iwanted), the 73-79s are good work trucks, play trucks, and daily trucks can't go wrong with one( except mpg,most suck)
the newer 87-91 or 92-96 would be a good first truck still built ford tough. with better mpg
Grappler150
08-09-2013 02:36 PM
khakushia
09-19-2011 10:23 PM
clean79150
08-29-2004 07:44 AM
