removing a/c clutch
on
It's behind the pulley. You will first have to remove the clutch plate, then take off the pulley. There are special tools required that you can probably borrow at Autozone or Advance. Just be very careful when screwing in the puller, there is a ceramic shaft seal up inside the shaft that is kinda fragile (ask me how I know).
Mike's 77
04-01-2009 09:54 PM
