FE rear sump oil pan
I have performed a crown Vic front suspension swap on my 66 F100. However my front sump oil pan for my 390 no longer fit. I cannot find any "stock" rear sump pans online.
Does anyone have any leads on one? I had no idea the oil pan would stop my project.
Thanks in advance
Thanks in advance
Thanks in advance
Thanks in advance
Here is a photo to give you an example.
I've seen them on Ebay occasionally, but for a pretty couple of pennies. I found mine on a truck the dealership I used to work at was stripping down. A coworker and I bought the non-running engine and I took what I wanted. It did not come with the dipstick tube, but I discovered that a tube from a MD GMC 366 fits in the rear sump pan beautifully after making a bracket to bolt it to and a little bending. The stick needs to be remarked as well.
rear sump oil pan
Assuming you are only looking for something stock, 1967 - 1976 Ford 4x4 pickups with a FE engine have factory rear sump oil pans. If you go down this route, you may have issues with the current location of your dipstick. If you aren't against after market parts, you can find rear sump oils pan on Summit Racing's website ranging in prices from $50 - $300.
amikeinkc
11-08-2005 01:56 PM
Dave 69_88 F Series
02-17-2003 01:51 PM
