Re-create bed side roll
I'm not sure....but I will subscribe to see who chimes in.
I have seen guys fix a bent up side roll by cutting off the old side roll and welding in a piece of steel tubing of the right size. It does close in the gap, but most of us wouldn't notice.
You could call the guys at Northern Classics...they make those parts at their factory in Michigan. I visited the shop there a few years ago. They weren't making bed sides on that day.
Dan
Dan
Since I was going the custom route, I teardropped the end leaving the end of the tube open for led lights.
LOL, that's somewhat of an exaggeration; it's a machine none of us is going to have in the shop. But it's possible a local sheet metal fab shop would have one. With 6.5' working length, not real likely.
Plate roll / Sheet metal roller / Plate roll bending / Rundbiegemaschine Motor / HengerÃ*tÅ‘gép - YouTube
All jokes aside, you half tonners have it so much easier on some things.
I don't think its too much of an exaggeration. Ford would have probably used a machine that would have stamped the part in some kind of progressive punch that would have taken a matter of few minutes. The system probably pump out a couple hundred parts an hour, I don't know for sure, I wasn't there.
I wouldn't use electric conduit, welding galvanized metal is a mess, way better off using thin wall steel tube. I used black water pipe because I didn't want it ti get dinged up like the original thin metal.
Midfifty has some lights that go into the bed side rolls. I'd try there first. Found a pair, led, for $135. Part #0244-25 or regular bulb #0228-RN
Received 4,135 Likes
on
Most affordable rolling machines won't make a tube smaller than about 4" It would be difficult and expensive to make a small diameter roller >6.5' that would not flex from the metal pressure and handle the thickness of a bed side. When you are forming thousands it is cost effective to build a task specific forming machine. maybe something like this (?):
A blank sheet would be place in notch of tool, a clamp raised to hold it. A roller follower would bend the metal around the form.
on
