'54 getting too loose - suggestions?
#31
#32
#33
#34
and the drivers side. Had to rework the brake line. These shocks are for a VW beetle. They have a min. length of 10-3/8 inches and a max length of 16.5 inches. That's the shortest length shock I could find that has a loop bushing and sleeve on both ends and what I considered an adequate travel length for the conventional geometry on a '54 F100. The min. length for the stock shock is about 1 inch longer and that would have put the lower end that much closer to the ground. The shock for a C1 - C3 vette has a min. length of 9.5" but a travel length of only 4.5 inches.
WOW, did I mention how much better my truck rides and handles with rear shocks?
#35
Ok, so you want to know why I didn't mount these using the same geometry as the original set up. Well, with lowering it several inches the original shocks were at more than 45 degree angle and when loaded they actually hit the frame rail. They also get in the way of mounting a spare tire under the bed, well the cross member for the shock upper mount and my hitch receiver. I wanted the shock more vertical and someday I might replace these with a pair of Monroe MA803 air shocks to handle heavier loads, like pulling my camper trailer, so locating the upper end on the side of the frame rail and in front of the C knotch seemed best.
Old setup.
Old setup.
#36
#37
#38
Now I'm working on the front suspension. It was a little loose - not the NASCAR kind of loose - it just like to wander around. In this video I show you how bad the steering box is. The upper ball joists are a bit loose too. I suspect all new wear parts will help tighten it up a bit. In the video I say 1/4 inch regarding the free play in the steering box but I meant 1/4 turn. Actually it's about 1/8 turn - that is the steering wheel would turn about 45 degrees with no movement of the pitman arm.
#39
Your top rear shock mount looks good but not sure about the bottom one. The photo maybe not showing the end of it well. With low mileage you might be ok but best keep a check on it. That style of fitting is normally designed to be in double shear. If you combine single shear with higher loading it could break or fatigue.
okedokeno
19
04-07-2012 10:39 PM
AmericanROCKBREAD!
03-07-2012 08:12 PM
Old F1
04-19-2009 09:20 PM
TheTinian
49
07-05-2008 06:08 PM
