2001 X Code Springs
2001 X Code Springs
I have a 2001 F250 CC 4X4. I am wanting to change my stock 14 year old V code springs out with new X code springs. I am thinking the front will be sitting higher than the rear after doing this. Do I need to order the F350 blocks for the rear? And if so, do I need to shim the Carrier Bearing for the drive shaft?
Thanks for any help!
Stewart
I have stock B codes on the rear with 2" blocks
Thanks!
What Stewart is getting at is "Ford OEM X Code Springs" can be marketed as such, but are not the same. It's real Ford OEM, or it's not.
In other words...the only place Ford 'X' code springs can be obtained is from Ford. The 43-818 aftermarket spring is not the same. I am curious as to what the rating process is and what are the differences between the Ford spring and the aftermarket one. And depending on what you want to use your truck for a good spring company can add leaves to a stack to beef it up if you need it. I am currently running the 43-818's and so far so good.
I don't need the X code rating, other than wanting the taller stance. I will be ordering my springs from Sunrise Ford or Tousley Ford. I have a friend that just put a set of the
43-818HD on his 99 F250. But I have read mixed reviews on them. His pretty much sets level now, but his 99 has 3 1/2" blocks in the rear. I'm trying to find out if OEM X codes need the 3 1/2" block for the rear. I don't want the front higher than the rear.
Thanks
Thanks
Why don't you go for the W code springs then? If the specific rating of the X code isn't your primary want, then the W codes might be more your cup of tea.
If you're in SoCal down by Sunrise, then order from them if you can get them close to the same price as Tousley because the shipping from Tousley will be a big cost.
Yes, all things being equal and on a stock suspension, you will more than likely need the larger, 3.5" tapered blocks.
Stewart
Thanks
Thanks
Stewart
I just replaced my CC's worn (one was broken) V codes with 43-818's over the weekend. I got the springs locally from a spring shop. Woodward Spring; Brockton, MA.
My truck had a serious rake before the swap with the front sitting fairly low. Now it sits almost perfectly level, even with the stock F250 rear blocks.
<a href="http://s63.photobucket.com/user/grecoface/media/2001%20F250/2A50E553-8A17-4689-A4A7-A24533B05951_zpskyzd1uur.jpg.html" target="_blank"><img src="http://i63.photobucket.com/albums/h126/grecoface/2001%20F250/2A50E553-8A17-4689-A4A7-A24533B05951_zpskyzd1uur.jpg" border="0" alt=" photo 2A50E553-8A17-4689-A4A7-A24533B05951_zpskyzd1uur.jpg"/></a>
I know you didn't ask for mine but thought I'd throw them out there. I went and looked at my old invoice and my replacements were 43-818's. The top 3 pics are before and the last two are after. It was more than a 1 beer project. My driver side droop was more than the passenger side but all even after the spring change.
