F 250 2004 Problem
F 250 2004 Problem
PLEASE I am having a debate between two shops that worked on my truck !One shop did hub assemblies ! The other did ball joints !According to both shops they both have some type of instruction data.One says it means to take ball joints out you must take axle OUT ! The other says you don't take the axle out! What's the difference ? Cause axle seals are missing which causes automatic 4 wheel to engage ! One mechanic that did hub assemblies says HE DID NOT TAKE axles off,so if he did not he could not be responsible for missing axle seals/excluder seals.Other mechanic who did ball joints says he didn't take axles out to do ball joints ! ( He is the owner not the actual worker that worked on truck )I have been told and saw a post that axles HAVE to come off to do ball joints ! PLEASE help with your thoughts ! THANK YOU !
If you would have looked in the Tech Folder (up at the top of the forum, marked READ FIRST) or performed a search, you might have found this:
https://www.ford-trucks.com/forums/3...ll-joints.html
That will answer your question.
Thank you watching thread that had pics other mechanics input plus Common sense tells us AXEL HAS TO COME OUT to do ball joints. Thank you all !
02 Super Duty Guy
1999 to 2016 Super Duty
11-30-2013 04:48 PM
shade1965
03-04-2010 06:12 PM
