Duallys Only
#1576
Those of you using the Cat Eye or similar dual tire pressure balancing systems... have you experienced any tire/wheel balance issues?
I am getting a vibration over 75mph and I suspect it is my Cat Eyes... tho I have no idea how I will address the issue if it is in fact the Cat Eyes.
#1577
#1578
I bought a case of this. Use it in my 17.5" trailer tires and puti ti the fronts on the DRW.
Got rid of the vibration I had on the truck.
http://http://www.liquidtirebalance.com/liquid_tire.htm
123 32 ounce bottles was $171 delivered
#1581
#1582
The Goodyear dealer that first used it had no issues.
I could see if perhaps I didn't let a tire tech know in advance to be aware of it. But no different then beads.
#1584
Received 5,252 Likes
on
#1585
When you use the liquid do you add it in addition to the weights on the wheels or do you remove all weights?
#1586
#1587
Some people use anti freeze. Cheaper, and doesn't freeze at night or boil when the tire is running hot. But with only a 15 degree bead taper on 19.5" rims, I wouldn't use it. The 5 degree bead taper of 16" and 17" rims is probably more tolerant to the potential lubrication that could cause bead slippage.
Tire shops don't use lead anymore in wheel weights on the west coast. Not sure what the weights are made of these days, but it takes more of them to achieve the same weight. I eschew weights altogether and run Centramatic Dynamic Balancers on my dually, but there is a good argument in favor of balancing media inside the tire itself... which distributes over a longer radius than either wheel weights or a captive media balancer on a disc, making less net weight work more efficiently.
#1588
Crack heads smashed my window yesterday morning.
Nothing taken, went through front area of cab, glove box, console, didn't find anything. Smells like an empty beer can bin now, and cheap wine. if I find evidence of a hobo sex party once I get home I'm gonna lose it lol.
Sorry to hear that...I know the feeling, had my tailgate stolen recently...
#1589
