92 f150 4x4 5.8 with e40d trans trans acts after 40 mile/ hour engine revs up kick overdrive off and it work for little bit then overdrive kicks back on by it self and same thind againe code 636 trans temp to low or to high any help out there truck has 109,000 miles on it
do you have a trans temp gauge? is the fluid burning up? hows it look? pull the rear trans line,start the truck for 2-3 seconds.did the fluid pump right out of the line with authority? you can test/have tested your solenoid pack (tot sensor specifically) too.
