Running rough when first started
Old 02-13-2015, 06:06 AM
95schauf's Avatar
95schauf
95schauf is offline
My 95 has been dragging a little when I start it. I have suspected the batteries or the starter fading. Now lately it has been running rough at first almost like a gas motor does when not hitting on all cylinders. It seems to run fine once it is a little warm. Not sure what it might be but any help would be appreciated. Thanks.
Old 02-13-2015, 07:03 AM
wils3825's Avatar
wils3825
wils3825 is offline
How long does it take for it to run normally?
I would guess this has to do with glow plugs/ GPR, but I'm far from an expert (Pretty new to the 7.3). Someone else may be able to point in a better direction.
Old 02-13-2015, 04:25 PM
427 fordman's Avatar
427 fordman
427 fordman is offline
Unhook the batteries from each other and get them load tested. If they check ok, make sure your grounds and cables are ok too. If all that checks out, your starter is probably shot. Get it cranking like it should first.
You can test the gp's at the vc connections. Outer pins on the vc gaskets. Should read real close to 1 ohm each. GPR can be tested too. With the key on, there should be no more than .3 volt drop between the big posts.
Old 02-13-2015, 06:57 PM
95schauf's Avatar
95schauf
95schauf is offline
It acts like at first it might be a low voltage problem like batteries or starter but i am unsure if that would make it run rough on the older trucks. The ucvh are all pretty new maybe a year old. still could be the problem i guess but I was hoping maybe something different. The last time i checked the oil it didnt have that burnt smell like they get. Also the glow plugs are about the same age. The hard start doesn't seem to have anything to do with the way that the truck runs it has done the hard start long before it was running rough when cold. Like I said the thing that is odd is it seems to run fine when warm. Maybe about 10 minutes of idle time at the most. I don't change the oil very often as the truck doesn't get driven much but I have heard the oil can get thick just from age and not miles but I'm not sure.
Old 02-14-2015, 09:54 PM
sean9049's Avatar
sean9049
sean9049 is offline
the whole "runs fine once warm" is why glow plugs and gpr came into question, try plugging your truck in and see if it skips the running rough part, if you dont see your heater cord it comes out by the oil filter base as a red cable and turns into a insulated three wire group with a wire guard around it, it should end up around your core support and grille area, changing your oil if it is old would always be a good idea even if it has low miles, these trucks have a heui injection system that runs off of oil, good luck!
Also when your starting it is it a fast crank or slow crank? and letting your glow plugs warm up longer than the WTS light doesnt hurt since they actually have different timers ( glow plugs having the longer timer )
Old 02-15-2015, 08:47 AM
Tim at pis's Avatar
Tim at pis
Tim at pis is offline
If it begins to run better once the oil temp rises it is likely warn injector oil sides. Once the oil warms up and thins out it can flow better through the injectors. When it is cold and thick it can not flow well enough to completely inject the full amount of fuel as requested. How many miles on the injectors/brand/oil change intervals?
fjord350
11-22-2018 12:00 PM
hasteranger
02-20-2013 09:33 PM
Jim McCarty
12-21-2008 04:07 PM
Lanny Sutton
30
01-09-2007 02:07 PM
fordpower88
08-24-2006 06:21 PM
Quick Reply: Running rough when first started
