NOS! 1997 Ford F-250 4x4 DIESEL
Old 02-14-2015, 07:08 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
C'mon guys. Quit knocking us dumb people
Old 02-14-2015, 08:20 PM
BBslider001's Avatar
BBslider001
BBslider001 is offline
Yep, agreed....fishing for morons....I love how the guys can pick apart ridiculousness when it shows up.
Old 02-14-2015, 09:00 PM
sean9049's Avatar
sean9049
sean9049 is offline
WOW! If i buy another truck im taking plenty of pics and letting you guys do the work for me
Old 02-15-2015, 04:49 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Originally Posted by madpogue
The E4DOA, the California fuel/electronics cr@p, .....
Actually the Cali emmisions is a good thing.
I would like to see a 49 state truck make 300hp to the tires with stock injectors like my Cali truck does
Old 02-15-2015, 05:13 PM
madpogue's Avatar
madpogue
madpogue is offline
Esp. when you have to replace the fuel pump......
Old 02-15-2015, 06:01 PM
Diesel_Brad
It was a ROYAL PITA to find 49 state banjo bolt when I did mine. it would of been cheaper and easier to just keep the cali pump
Old 02-15-2015, 07:09 PM
Talyn's Avatar
Talyn
Talyn is offline
Holy hell, he's selling my truck! WTF! =)
Old 02-15-2015, 07:10 PM
Talyn's Avatar
Talyn
Talyn is offline
That's cause the split shot injectors are a bit less anemic than the stock injectors for the OBS.
Has nothing to do with it being a "cali" truck, and everything to do with higher CC injectors out of the box.
Old 02-15-2015, 11:28 PM
fordman67's Avatar
fordman67
fordman67 is offline
lol 300hp
Old 02-16-2015, 01:51 AM
Thor'sHammer's Avatar
Thor'sHammer
Thor'sHammer is offline
Nobody noticed that it's missing a tail pipe? I can see what looks to be a turn down just after cat, but it ends there. I also noticed the add-a-leaf, along with the missing clamp on the front axle shaft slip joint, meaning the front end has likely been apart too. It also has adjustable upper ball joint slugs installed.
I can tell you though, it needs leaf spring eye bushings... Those are some the worst I've seen. The bolt is nearly touching the leaf spring in the middle of the eye.
Old 02-16-2015, 07:00 AM
Diesel_Brad
Has nothing to do with it? Cali injectors are 30% larger aka 120cc of fuel VS 90cc of fuel. I like I said, I would like to see a 49 state truck make 300HP to the tires with the stock injectors
Originally Posted by fordman67
lol 300hp
AGAIN, STOCK injectors A $300 chip and I had 300hp to the tires. Not a 1500 set of injectors and a 2000 turbo
Good eye. I really had to look for the turn down
Old 02-16-2015, 09:46 AM
MOOSE_MACHINE
Brad you should read talyns post better. He clearly state larger cc injectors has to do with it. Nobody doubts you've dynoed 300. I've seen 340 on 140cc splits.
  #28
Old 02-16-2015, 11:50 AM
Diesel_Brad
I did read it
The california truck had the larger injectors, that is why they are capable of making more power. Split shot or not
And the larger injectors ONLY came on California emission truck, so YES it has EVERYTHING to do with being a cali truck
  #29
Old 02-16-2015, 05:07 PM
majorgator's Avatar
majorgator
majorgator is offline
Nothing "rare" about a well-detailed truck. Heck, if trucks like this were so "rare", then forums like this one wouldn't exist (or should I say, the NUMEROUS forums like this). I always get a little giggle when I see terms like that in order to make it more appealing, or like how the ad says "family owned". Really?? 99.9% of the vehicles on the road are family owned. Its a pretty truck, but I'd rather see what it looked like prior to the detailing, painting, and bed liner. Not ever worth $23K for a reg cab.
Hjabernathy
2017+ Super Duty
42
09-28-2018 08:47 PM
ATC Crazy
6.4L Power Stroke Diesel
10-25-2014 12:24 AM
OAGES
31
05-07-2011 11:51 AM
twodivdeep
General Diesel Discussion
17
05-31-2008 06:23 AM
parks911
General Automotive Discussion
06-25-2004 01:24 PM
Quick Reply: NOS! 1997 Ford F-250 4x4 DIESEL
