1978 - 1996 Big Bronco
1987 front axle interchange ?
Old 02-10-2015, 07:16 PM
Y2K1TON's Avatar
Y2K1TON
Y2K1TON is offline
I have a bone stock 87 bronco with 373 gears. The manual locking hub has broken on the drivers side. It is not the style that has the bolts around the perimiter that hold the locking hub on, its some different style not very popular.
I cant find a replacement lock/hub so I thought Id swap the entire front axle assembly with another.
My question is what axle assembly should I be looking for that will bolt in place?
thnx
Old 02-10-2015, 07:39 PM
andym's Avatar
andym
andym is offline
Good call on the swap. It's what I would do. That '87 axle with the flange hubs was a horrible idea.
Any Dana 44 TTB from a 1980 to 1996 F-150/Bronco will bolt up. There really weren't many changes except to the caliper mounting style and possibly the u-joint style. If you have new calipers or otherwise want to keep the brakes you have now, make sure the donor axle is the same style.
Old 02-10-2015, 08:00 PM
Y2K1TON's Avatar
Y2K1TON
Y2K1TON is offline
thnx for the quick response.
This bronco has been in our family since brand new. my father in law bought it new then passed it on to my wife and I, and now our youngest son (17) will be driving it daily. Just want to make it safe for him.
chrisfp178
01-31-2017 07:39 AM
nikizmon
06-30-2013 09:20 PM
FastEddy760
06-22-2009 09:01 PM
fenix1
Bronco II
09-29-2006 11:20 AM
skipper
03-08-2002 02:32 PM
Quick Reply: 1987 front axle interchange ?
