Additives for water pickup
What are the best additives for water elimination in the fuel? Have an Allmand backhoe with a Kubota 3 cyl. diesel engine. No start right now (10*), ice in the fuel filter (changed it). I use an anti-gell additive plus Diesel 911. Still water in the fuel. Cap is covered and plastic tank kept mostly full. Usually "over treat" with the additives. Any suggestions? Thanks
Received 3,110 Likes
on
on
Unlike a gas engine, a diesel can't deal with dispersed water. You want the water to drop out and then separate it before the pump.
If this is an ongoing issue with this machine, I would add a clear separator before the lift pump and drain as needed.
Sent from my Brigadier using IB AutoGroup
Have a great day!
RickBraden
6.7L Power Stroke Diesel
34
12-26-2015 11:14 AM
