turbo 4.9l any thoughts
well u not the only 1 that has given this a thought cause iv been thinking the same thing . but one of the problems with the 300 is that its good for warping the head , so if u going to boost it u can only use very low boost . it would make a good truck with the 300 as it gots lots of tork an the turbo would build up that lost in the mid range of the motor an top end to . so over all it would be lots of tork on tap at all times
This has been covered at length. Use the search function. For the best thread see
https://www.ford-trucks.com/forums/s...threadid=98573
One more place to look is www.fordsix.com ...We've covered this issue many times and have many pople on the building stage.
Madmechanic
11-04-2007 09:45 PM
