'03 6.0 with 4r100 transmission
Old 02-08-2015, 08:57 AM
goneinsixty's Avatar
goneinsixty
goneinsixty is offline
I have an early build f350 with a 4r100 transmission. Came that way from the factory. Everyone says impossible because only the 7.3 came with it. Tranny is going can I swap to the torqueshift and should I?
Old 02-08-2015, 09:00 AM
jmtbiggin's Avatar
jmtbiggin
jmtbiggin is offline
Subscribed and curious
Old 02-08-2015, 09:01 AM
texastech_diesel's Avatar
texastech_diesel
texastech_diesel is offline
Token Redneck
How did you verify that it's a 4R100? The 7.3L bell-housing pattern is different, a 4R100 trans from a 5.4 and 6.8 gas motor would bolt up, but it wouldn't have come from the factory in that setup.
mustang_309's Avatar
mustang_309
mustang_309 is offline
If you want to know what tranny your truck came with go to www.fordparts.com and enter your vin number and do a parts search, it will show you on the upper left hand of the screen what transmission it has. I have always understood that the 6.0L was only offered with the torqueshift automatic or a manual transmission.
Old 02-08-2015, 09:06 AM
78fordman's Avatar
78fordman
78fordman is offline
The transmission control is very different. it is not a simple swap. Your truck is not supposed to exist. Are you 100 percent on both the 6.0 and the 4r100?
Old 02-08-2015, 09:23 AM
goneinsixty
well... 100% 6.0. I guess I am making an assumption on the trans because it is only a 4 speed D321. I will verify with the vin and post back.
Old 02-08-2015, 09:27 AM
Money-Pit's Avatar
Money-Pit
Money-Pit is offline
Do you have a tow/haul or overdrive off switch on the steering column?
KDAVID1's Avatar
KDAVID1
KDAVID1 is offline
You have a hidden gear
2006 F350 4X4
Old 02-08-2015, 09:28 AM
goneinsixty
tow haul on the shift column. Fordparts.com says torqueshift. Why if a 5 speed do I only show D321?
Old 02-08-2015, 09:44 AM
goneinsixty
Glad I asked. Thanks everyone for the help
Old 02-08-2015, 10:29 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,593 Likes on 1,067 Posts
Because Ford wouldn't spend the money to add a '4' position.
Here's what would have to happen to install a 4R100 at the factory.
Your truck would need a custom driveshaft (2 if it's a 4x4) because the TorqShift is a different length. It would also need a custom wiring harness because the 5R110 harness wouldn't connect to a 4R100. And then someone would need to create a custom computer and software to run a 6.0L/4R100 combination. Ford didn't do this, so how would all of this come together in the factory? It is IMPOSSIBLE for this to happen.
Old 02-08-2015, 10:38 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
Didn't I read somewhere the TorqueShift is technically a 6speed (two three speed boxes in one case) with third and fourth so close together in ratio it selects between the two depending on conditions. Bad info?
Old 02-08-2015, 11:41 AM
RideDiesel88's Avatar
RideDiesel88
RideDiesel88 is offline
He'll realize its a 5r110 when he changes the internal filter
Old 02-08-2015, 11:55 AM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,123 Likes on 1,020 Posts
Why would anyone change the internal "filter"? I really ain't a "filter"...... it only keeps horses out!
Old 02-08-2015, 12:07 PM
RideDiesel88
ok so how else can you tell its a 5r110 right of the bat???? Filters are meant to be changed. And those filters are different sizes! just tryin to help the dude out not tryin to argue about stupid s**t
Quick Reply: '03 6.0 with 4r100 transmission
