Should I grind and finish these welds or leave them be???
Old 02-07-2015, 07:14 PM
clintonvillian's Avatar
clintonvillian
clintonvillian is offline
Old 02-07-2015, 07:15 PM
clintonvillian
Ok so I am pretty much finished welding these. I can grind them down, but I also don't think the welds look bad. They will look even better after blasting removes the final boogers..........
What do you think? Grind and finish? or leave them?
Keep in mind that no filler can be applied do the temps, and powder coating process.
Old 02-07-2015, 07:20 PM
Skalywag's Avatar
Skalywag
Skalywag is offline
As they say around where I live....them is to purdy to cover up.
They also say that about certain female body parts too.
Old 02-07-2015, 07:23 PM
bigwin56f100's Avatar
bigwin56f100
bigwin56f100 is online now
Thats so cool! I wish I could do stuff like that. I say leave it. Too bad it was made on the wrong side of the RIVER! Just kidding
Old 02-07-2015, 07:26 PM
clintonvillian
Wrong side of the river? I don't get it? lol
Old 02-07-2015, 07:27 PM
bigwin56f100
Ohia river
Old 02-07-2015, 07:33 PM
raytasch's Avatar
raytasch
raytasch is online now
Believe Nothing
OK, what is the application? Looks like it will work well as is. Shows lot of work. How many hours involved?
Old 02-07-2015, 07:43 PM
clintonvillian
probabally 50+ hours and it is for a 300 six
Old 02-07-2015, 07:58 PM
fabieber's Avatar
fabieber
fabieber is offline
If I could weld like that not only would I leave it as is, I would not put a hood on whatever vehicle it goes in so everyone who ever wanted to weld could see what could happen if you practice enough.
Old 02-07-2015, 11:32 PM
bobj49f2's Avatar
bobj49f2
bobj49f2 is offline
Received 2,059 Likes on 804 Posts
I'll have to be the deserter, I'd dress them up and make them smooth. I am also the type that doesn't like "patina" finishes.
Old 02-08-2015, 04:27 AM
AXracer's Avatar
AXracer
AXracer is offline
I'd have to grind them smooth so it looks like one piece, especially for powdercoating. Powdercoating raw welds will make it look "crude" IMHO.
Old 02-08-2015, 07:33 AM
Marauder2004's Avatar
Marauder2004
Marauder2004 is offline
Nice work! That will look really sharp on the side of that 300. I would like to have that kind of talent. I would be more inclined to grind them especially if you want a nice paint finish.
Old 02-08-2015, 08:19 AM
clintonvillian
I tend to agree, it just feels "unfinished".
The outer edges will not be an issue to dress and metal finish.
How about the fillets around the bungs and flanges? What is the best way to get them finished down?
I use a carbide bur, and a sanding drum. With this approach I still tend to "gouge" some places and leave rough marks. It is not typically an issue though because a good primer or a little filler will hide them. But in this case I cannot use it.
So, what's your recommendations on tooling?
Old 02-08-2015, 11:16 AM
gerrymoe's Avatar
gerrymoe
gerrymoe is offline
You have put alot of work into that project and should be commended for it. IMHO I would do the additional time of finishing the welds. Make the curves look like they flow and the edges roll. 8pc Dual-Cut Carbide Burr Set - 1/4inch Shank
Cylinder Porting and Finishing Kit
1/4"" 90 Angle Die Grinder 1/4"" Medium Die Grinder
Go slowly with light pressure and you will have a nice looking finished pc ready for the finish
Old 02-08-2015, 12:25 PM
clintonvillian
It is 16 ga. so i will not be able to really "roll" the edges. Just knock some of the peak off of them....
Quick Reply: Should I grind and finish these welds or leave them be???
